Hello Everyone,
I was thinking of insulating and hanging drywall in the garage and when I look up into the rafters in each of the 4 corners of the garage there is a diagonal beam that spans across the 2x4's from the bottom. I can't imagine cutting them away as i'm guessing it's a support beam. Does anyone have any ideas on how to drywall these areas? I've included a picture of one of the corners to give you a visual.
Also, if one were to insulate the vaulted area of the ceiling would one use insulation batts and install them between the studs of the ceiling as you would on the standing walls? or would you do it above the drywall or both?
I hope this is the right area to pose this question and I gave enough information.
The house was built in 1986 and is in southern California area.
