HVAC question- Just installed a new Genteq x13 blower fan motor, the high voltage part Is hooked up and fine, but the low voltage has me stumped. The old motor (9yrs old,same style plug) had 2 wires going to The low voltage section, white wire on terminal 4 from thermostat (and also tied in with other white wires Going to heat section) and Blue wire on pin 1 that I traced back to the green wire from the Thermostat, but it’s also tied into 24volt common side of the transformer. The diagram on the new motor
Doesn’t say anything about 24v common on the 1,2,3,4,5 connections. Should I go from green thermostat wire Straight to one of the fan speed connections or hook it up like it was?
comfortmaker split unit, electric heat, no control board in air handler.thanks
