Well, the roof is done. I had a Certainteed Integrity roof system installed. On my low roof, I had a Shinglevent II\Edge Vent combo installed. Looks pretty slick! Let's hope it works. On the main roof, the ridge was pretty short so I opted for mushroom vents. The back of my house faces west, so they recommended that I put most of the vents there (plus you can't see them from the street. I also have one on the North side and South side of the high part of the roof. I'm wondering now if this was the correct placement.
The ones on the far left and right are above my bedroom ceilings venting a little area that seems to be like a knee wall (when they cut out the wood for the vent, all they saw was the plaster ceiling. No insulation). The next two are actually on the low part of the attic wall just above my 8" of blow in.
I'm just wondering if I will get optimum ventilation with the placement of those 4 vents or should I of gotten more put on the north and south side. Since there is no insulation in those small sections, I'm guessing those rooms that are below are going to get cold in the winter?
Another question I was if I wanted them removed, is it a roofing no-no to remove the vents, fill in the holes, and roof over where the vents were and relocate them somewhere else now that the new roof is on?
Thanks for reading,
Lew
Thanks for reading,
Lew
