Brand new house built last year. Planning on building a deck in the back yard. Started by attaching the ledger to the band of the house, like all of the books say to do.
After attaching the ledger, the building inspector mentioned that it is approved, but he suggested adding additional support under the bay window.
The bay window is well supported, the floor joists in the house extend all the way through. I also re-enforced the house band by L bracketing it to the floor joists in the basement.
To add additional support for lateral load, I was thinking of either:
1) Installing a post under each end of the bay. Attach the post directly to the ledger.
2) Installing a Post and Beam parallel to the ledger, about 6 inches out. This would handle the lateral load and the ledger would merely be holding the deck against the house.
3) Fabricating steel brackets to go at a 45 degree angle. They would attach to the ledger and down 45 degrees to the foundation.
4) Attaching 1/2" x 5" lag bolts through the ledger and into the floor joists. This would of course be the easiest option, but probably the least effective.
I know that a complete free standing deck is another option, but would like to use the ledger that I spent so much time on. Any suggestions would be greatly appreciated.
I've attached some pics to show what I'm talking about.
It's funny, I took a walk around the neighborhood and noticed a half dozen houses where they simply attached the ledger like I did. No additional support. No sagging is evident, but the houses are all 5 years old or newer. I'd like to err on the side of caution.
