I'm finishing off my attic and I have a question. Is it generally ok to run Romex in the void of an A-frame attic? I'm planning to insulate the entire thing so there will be fiberglass insulation between all the ceiling joists. I've run a bunch of IC recessed fixtures along the flat part of the ceiling as shown in my quick sketch below. I guess I'm wondering whether I should have used conduit. I have plastic attic vents running from the bottom soffit up to the void created by the ceiling joists and I installed a ridge vent at the top for air flow. I figured since I could run Romex without conduit in my walls, the ceiling should be the same thing right?
