I purchased a new smart switch for our bedroom and it requires a neutral wire in the light switch box. The way the lights are wired, the power comes into the first lighting fixture and there is no neutral in the box.
The previous owner fancied himself a DIY guy and installed the recessed lights himself. I went up into the attic to see how I could re-route the lines to get a neutral in the light box, I noticed he wired the lights and run to the switch with 14g but the breaker in the panel is a 20 amp breaker. It appears the run to the breaker box was done in 12g wire, however (I need to confirm that, as I didn't look close enough).
Now I am faced with a dilemma. I can run all new 12g wire and keep the 20A breaker or the easier move might be to just switch out the breaker for a 15A one. I am not sure why he used a 20A breaker as the only fixtures on the line are the ceiling fan and then 8 LED recessed lights. I guess for future expansion?
Anyway, if I switch the breaker, I believe the codes have changed and new breakers need to be CAFCI, correct? Or because this 20A line was installed prior to code changes, can I just switch it out for a regular 15A breaker?
Thanks.
Thanks.
