Hello
This inquiry is related to irrigation, which is not the intention of the forum, but my specific question relates to reduction of PVC. And you experts will know better.
I have a well pump that feeds an irrigation valve using 1.5 inch PVC. Leading up to that valve is a sediment filter and a hose spigot.
I need to replace that indexing valve with electronic ones, and those electronic ones appear to be readily available with a 1 inch inlet; ones do exist with 1.5 inch inlets but they cost double or more. The tubing out to the sprinkler heads is also 1.5 inch PVC.
So my options are:
1. Build a 1.5 inch manifold and remain with 1.5 pvc all along and spend the extra money for the 2 valves - the easiest route.
2. Stay with 1.5 out of the pump, through sediment filter, reduce to 1 inch for the valves, expand back to 1.5 for the outgoing tubes. - the second easiest.
3. Redo everything out of the pump with 1 inch (spigot and new sediment filter) up to the valves. Then increase up to 1.5 after the valves to join the outgoing tubes. - the most expensive
The well pump has 1.5hp (ha) and is used 3 days a week to irrigate 2 zones in a moderately-sized front and back yard. Zone 1 has the rotors, and zone 2 has the sprinkler heads, and they won't be watered at the same time. The runs from the pump to the farthest heads are about 300 feet or so.
Will I lose a lot of pressure or flow or whatever if I choose options 2 or 3? Option 3 involves a bit more spending since I would have to buy new 1 inch tubing and sediment filter and spigot assembly.
Thank you
So my options are:
Thank you
