Hello. I painted a kitchen. I used semi-gloss enamel water base. The paint I applied today is pealing off. it is the same as when you put a masking tale on a wall and then you take off. The kitchen used to be painted with oil base paint. Now, I have to take off the enamel paint and start from the begining again. Any advice as to what to do next is greatly appreciated so the enamel paint I apply again does not peal off. Thank You
