Pretty novice when it comes to electrical stuff, so bear with me.
So I just rented a home where some of the outlets are the 3 prong grounded and some are the non grounded old style 2 prong outlets. My question is about the 3 prong outlets and if they're really grounded or not.
To start... I cut the power in the breaker box and took one of the 3 prong outlets out. Looked at the wiring and there's two hot wires and two neutral wires, but no copper ground that I could see. It was pretty dusty and dirty in there which I'll eventually get around to cleaning. After seeing no copper ground in there... I assumed that they were all non-grounded.
Got out the multi-meter and set it to volts. Hot to neutral read 122 volts. Hot to ground read 122 volts. Neutral to ground read <1 volts. Correct me if I'm wrong, but doesn't that mean the outlet is grounded?
I also plugged in a surge protector and it's saying it's protected... well at least the green "protected" light is coming up when plugged in.
What am I missing here? Are these outlets grounded or not??
