I just installed a bathroom heat lamp (thanks to the help I received on this forum) and I would like to know if I can put a dimmer on it. The instructions say that I cannot because it has a fan that blows the heat from the lamps down into the room. However, you can unplug the fan, which is what I would do. Also, since it's warmer out, I will be using 45 watt bulbs instead of the 250 watt heat lamps, but I would like to be able to dim them. I think that I should be able to unplug the fan and then dim the bulbs, but would like confirmation. Thanks a lot.
