Sorry if this is in the wrong category, but any help is very much appreciated:
Our natural gas, built in BBQ got old. We bought a new one.
When I pulled out the old one, I noticed the pipe coming out of the ground looked like PVC, but was yellowish in color.
The plastic pipe transitioned to the usual corrugated looking flexible line with the flared end that is used for example in water heaters. The transition was a strange looking metal pipe which I could not see how it joined the plastic.
When I put the new BBQ in, I smelled gas. Couldn't tell where the leak was since the opening for the BBQ in the block wall structure used to make the built-in was barely enough for me to fit in.
Nonetheless, I went in after taking the new BBQ out, and cut the PVC looking pipe below the transition point. So, now I had the corrugated line with the metal transition piece in hand and could look at the transition. It looked like the PVC was somehow stuck into the metal pipe. I took it to Home Depot of course. The guy said the plastic was NOT PVC and PEX. He recommended going to a plumbing supply place which I did. They told me it was NOT PEX but indeed PVC even though the color was yellow.
He said they do not make the union/transition any more. They had the PEX transition (metal to pex) but not the same with PVC as in the piece I had in my hand. He said I was stuck?!!
Well so that's why I am writing.
1- Has anyone ever seen PVC used for natural gas? The BBQ was put in when the house was built in 1990 or so and I suspect the had a permit and it passed code.
2- If PVC is usually used, can I just get a PVC piece to put on the pipe out of the ground to join it to say a short galvanized bushing which can then be transitioned to the corrugated flexible pipe with flared end and simply use that? What are the issues? There is already a couple of PVC joints in the pipe out of the ground (and used to be one where I cut it). The union will be about two feet below the BBQ bottom (where it used to be). Is there an issue about heat getting to the plastic pipe and possibly the joint?
I already tried this joint (PVC union which threads into a galvanized bushing which then can be adapted to the corrugated flexible line) using now a valve (I bought separately) at the end of the flared end which usually goes to the BBQ and turned on the gas and observed no leaks (I shut off the valve to mimic the case when BBQ is there with its valve). But I am hesitant to put the BBQ back in.
Again, any help is appreciated.
Thanks
Thanks
