I've installed a new closet toilet but had a problem with the rough in and needed to extend with a 3in PVC pipe outside of an existing T connect in order to install the flange. Thought I had a good seal but after a month the joint is starting to leak. Is there a way to seal or do I need to replace the entire drain
