J.V.-
I respect the knowledge here but I have a pragmatic streak. If my plan is unsafe I really do want to know, but considering that this is on the back porch under the overhang and only maybe twenty feet, I don't think that it will be unattractive if I paint the pvc when I paint the house as soon as I can get to it. I just figured the pvc would paint better and I was planning on installing several straps along the way.
I don't move as flexible as I used to, not to mention the heat in the attic so I really didn't want to get up there, even in the winter unless I have to. Actually, I probably would rather drop two sheets of trim from the fascia on the outside (or drill a hole and fish it) than get way over into the 12 inch clearance over the fascia from the attic. As long as I'm nearly 60, 30 lbs overweight, and acquainted with arth, burs, and most of the "itis" clan, I just don't see that happening!:no:
As far as romex outside, I did not know that. It seems that three wires wrapped in another layer (of the romex) and then inside the conduit would be as safe as three individual conductors.
I thought that BX is basically flexible conduit. Not so I guess. What I know as BX is metal armored cable with individual conductors inside. Is that correct?
