Our 2-story garage was built in 2006, and we are now finishing out the second floor. The permit was pulled and everything is on schedule. Because the garage measures 20' x 30' the ceiling joists for the second floor ar 20' long, and apparently only 18' ceiling joists are now available(?)
At any rate, the contractor and I noticed the following:
1). When you close the ladder (with springs) going to the attic the ceiling joists tremor somewhat (or vibrate) -- probably because they are 20' long.
2). When standing in the attic, if you jump a little, the ceiling joists flex slightly, which means that sheet rock joints (on ceiling of 2nd floor, screwed into ceiling joists) could fail over time.
We thought that we could drop vertical "purlin" 2x4's from the rafters down to the ceiling joists, and cut holes in the attic floor plywood so the 2x4's could be nailed in to the ceiling joists. We also thought of altering every other ceiling joist -- too many and you couldn't store anything in the attic. As long as there are 2 purlin joists per ceiling joist.
The contractor suggested jacking up the rafters because they are bowing, but my thoughts are just to tie in the vertical purlin 2x4's dropped from the rafters down to the ceiling joists -- which will help minimize flexing of the long 20' ceiling joists.
Couple questions:
-Do the rafters need to be jacked up, or should the purlin 2x4's simply be attached between the rafters and ceiling joists without jacking up?
-Aren't purlin joists angled like 45 degrees?
-For 20' ceiling joists, how far from the ends of the ceiling joists should the purlins connect, and what about the rafters (how far from the bottom ends of the rafters should the purlins connect)?
Couple questions:
