I'm working on a basement finish project, and need to add a light under the stairs. There are 2 3-way switches near where I want to add the new switch - 1 for the basement lights and 1 for the stairway light. There are 3 14-3 cables running into the box, so I assumed these switches were not at the start of the run. But I opened the box anyway. I found that 1 of the 14-3 cables has the red wire capped (not connected to anything). The black wire from this same cable runs to the common terminal on both switches. The other terminals are connected to red & black on the other 2 cables. I assumed at this point the builder ran out of 14-2 so just used 14-3 instead, and that I had a good source of power. But to be sure I traced the wire, assuming it would run back to the panel. It didn't. It goes to one of the lights on the circuit controlled by 1 of the existing switches. The only thing I can think of is the builder didn't have a single cable long enough for the home run, and used the light's j-box to "splice" the cable for the power source. It seems to me that's the only way the existing circuits would work correctly (which they do). But I don't understand all the 3-way switched circuit combinations. Are there any other possibilities, or can I assume I have a good power source?
