I recently bought an old house that was in need of a LOT of work. I am generally in the never-pull-a-permit-camp but now need some advice or at least some input because of it...
I had an electrician change out my electric service and run some new lines. I had a contractor knock part of a couple walls. I had a plumber run a new gas line and move a laundry tub. I had a roofer replace all of my fascia... no permits, no inspections
Now I'm looking at having central air installed. In my city if you want to install the compressor on the side of the house (which makes the most sense for me by far), you need the city's "permission". I'm guessing I would be granted that permission but I'm pretty sure asking for it would mean that pulling a permit would be unavoidable.
Questions:
Does the inspector come in the house only after the work is performed for something like that? Or is there a pre-check to make sure certain things are correct before work can proceed?
Has anybody heard of an inspector noticing previous work that was not permitted and giving the homeowner hell about it? Is there really any way to prove that I, and not the previous owner, did the work?
What is the true connection between code inspectors and taxes? Will the inspector say "hey, nice new kitchen" then write a note to himself that says "increase taxable value by $10k because kitchen is really nice?" Or is the only item that will increase my taxes the work currently being inspected, in this case the addition of a/c?
Thanks in advance
Questions:
Thanks in advance
