The old wires of the light look a little sketchy in the picture. But if not too brittle could be reused. If you visit a lighting store rather than a big box, you will find lights with the vintage look you're seeking. But that will defeat you saving money , but could be offset by more energy efficient bulbs.
If you reuse the old lights, be certain that you determine which wire of the light is the neutral. The neutral should connect to the outer edge of the socket not the centre. The light will work if reversed but can be dangerous when changing bulbs while the power is connected.
A metal box would require a connection the the ground in your panel, but new cable will have a ground wire in it.
