#1 - the flow is from right to left - I was told by a city plumbing inspector that on a horizontal run such as this, a 90 degree elbow was not permitted - but 2 - 45's should be used.. is this correct? any minimum distance between the 2 - 45's required?
#2 - flow is from right to left - same question above about the 90 degree elbow on the right, and the t-connector on the left - should that not be a Y-connector?
#3 - this is a horizantal run, flow is right to left - should the 3 or 4" T-connector not be a Y-connector instead?
#4 - flow in large pipe is right to left.. is this a proper connection?
#5 - flow is from right to left.. is this a proper connection?
thanks for any helpful comments...
