1 - 19 of 19 Posts
Hello, I'm having a problem with the condenser fan motor in my heat pump. I've narrowed the problem down to either a bad run capacitor or bad motor. I'm going to replace the capacitor first and hopefully that will fix the problem. But if the new capacitor doesn't fix the problem, I plan to replace the motor.
My heat pump is a 25 y/o Trane with a GE condenser fan motor. I can't find the exact motor replacement, but an online vendor has found me a replacement Fasco motor (model D787) with the same HP, RPM, VAC, etc. However, after looking at the replacement fan motor specs, I see it has an open-air-over enclosure. The old GE motor has a totally-enclosed-air-over enclosure.
I don't know much about these motors, but since the motor is going to be used outside and exposed to rain and snow, it would seem to me that a motor with openings in the enclosure should not be used in that environment.
Am I correct in that assumption, or am I totally off base?
Thanks!
Gary
What's the motor doing.
Why not check the capistor to see if it's bad before replacing?
Thanks for your reply. The motor runs for a while and then begins to slow down and speed up. Eventually it runs slower and slower and then comes to a complete stop. I checked the motor the last time it happened and the motor was very hot.
I don't have a multi-meter that measures capacitance. Is there another way to check if the run capacitor is bad or not?
· Retired
Just something to think about, but there has been a few occasions that I found the problem to be in the control card. I had to replace the control card after the new replacement fan didn’t operate. Also did you check the contacts, I found one that was barely making contact and getting hot causing a resistance.
Good luck!
Discussion Starter · #9 ·
Your OEM motor is a MOT02642, 1/3 HP, 1625 rpm. Get a local contractor to order one for you, or we can secure if no others can. It's not an open motor.
Thanks for the replacement motor information. I have another question you might be able to answer for me. Are there differences between the MOT02642 and the MOT02602 motors? The specs appear to be identical to me.
Thanks again!
We don't mean to offend...but you're unit is old. 4 other alternates come up: MOT03336 , 4570 , 4572 , and 4889. Specs do look same on 2602 aside from the 4mfd capacitor. Our records show the 2602 to be an older motor found in GE BGTA models, typically 2-1/2 ton
Discussion Starter · #11 ·
Don't worry - no offense taken. I know my unit is old. I'm just happy it's lasted this long (25 years+) without needing any major repairs.:)
I value and appreciate all of your feedback and the useful information you've provided.
Discussion Starter · #13 ·
Just an update ... I replaced the run capacitor, but that did not resolve the problem, so it looks like the motor is the culprit.
One concern I have on a replacement motor is the rotation. The motor in my unit rotates CW (shaft up), but I see that some of the vendors who have the MOT02642 motor available, show its rotation as CCW.
Anyone know if those motors are reversible or not? Thanks.
Gary
Discussion Starter · #17 ·
Hello again ... I thought I was finished asking questions, but here are a couple more.
An online vendor recommended an Emerson 7232 motor to replace the one in my unit. They said they couldn't get the MOT02642, but the specs on the Emerson 7232 match.
Any thoughts on the Emerson 7232? I saw that the mount on the Emerson motor was hub ring. I have a belly band mount in my unit. Would that be a problem?
Thanks again!!
Gary
We have confirmed that the MOT02642 are readily available at the factory - I'd suggest another vendor or secure one locally thru a Trane or American Standard Dealer? This OEM Motor is pricey. The resilient mounts are often standard on blower wheel , at a 48 frame most likely it can work with a belly band no problem. Make sure Amp Rating and SF - Service Factor are correct for your application with the MOT07232.
Discussion Starter · #19 ·
I was able to find the MOT02642 motor from several vendors online. Even the vendor who told me it was not available found the motor after I told them I wasn't interested in the Emerson motor. Ironically, they ended up having the lowest price once they located the motor.
1 - 19 of 19 Posts
