I have a receptacle installed by my builder which I am trying to replace with one which includes USB ports. I got an Eaton TRUSBAC15 which includes a USB-A and a USB-C port, as well as two regular outlets. Today I did the replacement and ran into three problems.
1. It's quite big and I hard time getting it into the box, because of the long 12Ga wires the builder used. It also has a pair of wires going to a second receptacle, so they all are hard to fold up enough. There is no width or length problem. It is still about 1/4" proud from the wall; I was thinking about getting an extension. Any well, I thought I would try it out, so:
2. I plugged my phone charging cord into the USB-C port and my FM radio into one of the regular outlets. The cord went to a non-contact charging disk. The radio had a buzzing background noise. I removed the phone cord and plugged it into the wall wart which came with it and there was no noise.
3. I finally realized that it is a 15A receptacle on a 20A AFCI circuit. The only other thing on that same circuit is that second receptacle which gets its power from this one.
I could solve the last problem by changing the AFCI breaker to a 15A one. (All the wiring in the house is 12Ga or larger size).
I might be able to solve the first problem by cutting the wires shorter so I could fold them up more efficiently or open up the wall and putting in a larger box; this seems a little extreme.
It actually wouldn't be too difficult to run a new line, with a new, larger box and different outlet, but without buying a different one and trying it out, I wouldn't know about the radio interference issue.
I probably should just give up on this project and restore the original receptacle, but does anyone here have another solution?
