Hi,
A few days ago I installed a new 110 circuit to add some lights and a fan. The box was a bit tight and the new breaker had to go at the bottom so it was easier to route if I popped off the upper ones an swung them to the side.
I reinstalled everything and restored power and everything seemed fine, except 36 hours later I had no hot water, zero. I pulled the panel on the heater and tested the red and black lines going to the main block and got 0 volts instead of 220. I went back to the panel and tested between the two circuit breakers and got zero. when I test between either of them and ground, I get 110, but between them, 0.
I'm far from expert but it seems as if I wired them out of phase or something. The two GE breakers in the circle are for the WH circuit. I'm pretty sure I connected them back to the same lugs they were on, but not 100% on it. The gap above them seems a bit odd. On the left of it there is a grab lug to hold the back of a breaker, but there is no connector lug in the center so I don't see how a breaker could go there.
Any ideas what I'm doing wrong here? I really need a hot shower
Thank You,
Eric
http://farm3.static.flickr.com/2432/3659987843_b47c0e23e2_o.jpg
Thank You,
Eric
