The house I recently bought had a regular receptacle--no cover or anything--just outside the front door. I wanted to replace it with a GFCI and a proper cover. Here is what I've encountered so far:
1) I tested the existing outlet with a receptacle tester. Only the red light came on (both receptacles gave the same result). I took this as a suggestion that the neutral was open and the polarity was reversed.
2) I flipped the breaker and removed the outlet, which was a cracked and rusty mess. The previous installer had used the back wire push-in connections, but the black and white wires were each on the correct side and appeared intact. The ground wire was present and intact. This is apparently the last outlet in the circuit--nothing else is loaded on it.
3) I installed the GFCI in accordance with the instructions and flipped on the breaker. The GFCI will not reset (not really a surprise) and my multimeter tells me I have about 7 volts coming through.
Any insights? I just want to make the thing safe. I don't even need the outlet there, to be honest.
