Hey Guys,
I have a problem with my septic drain field that I'm hoping you can offer some advice on. The house and septic system are only a year and a half old. The septic system is a 1500 gallon pump system. The tank is down the hill by the house. From there, it uses a pump to pump it up the hill to the back of the back yard. Up there, there is a hydrosplitter that distributes it to seven leech lines. The first line is the shortest of the seven (not sure if this matters).
The problem that I'm having is the ground above the first leach line is wet. Really wet. It's wet for the entire length of the line and has been for a while. The ground above the other six lines is completely dry. The hydrosplitter has a seperate run to each of the seven lines.
I've described the system, but am not a plumber, and don't know anything about how a hydrosplitter works. Does anybody have an idea of where the problem may lie? The installer has gone out of business.
Thanks,
David
Thanks,
David
