1 - 13 of 13 Posts
Have a very strange problem. It started with our dryer not working all of a sudden. Thinking it was the dryer then found out the oven didn't work also. (both on the same breaker). Instantly figured it was the breaker. Replaced it, and still nothing.
Tested the voltage in BOTH outlets. Full power. Now both the dryer and oven have Power Failure flashing, and I don't know what to do. Tried everything with the breaker wires. Tried running the dryer without the oven, and vice versa, and nothing.
The dryer is getting some power. When I hit the power button it flashes on really quick but shuts off. The oven, clock works, timers work, just no heat.
I'm running out of ideas.
Electrician
First off are you sure they are on the same breaker, these two items should have a dedicated circuit.
How did you test your devices. You should be testing for voltage, 240V between the two hots(red and black) and 120 from black and red to ground and neutral.
Since you say your timers work, my first guess would be that you lost one of your hots.
Test both hots to ground or neutral and see if you get 120V from each.
Well its a double circuit. 40a to each. And yes, I tested for 240 volts.
Discussion Starter · #7 · (Edited)
I guess I failed to mention I live in a trailer home. The breakers are much different I think.
I guess I call a "2 pole" double circuit :/ but yes, the oven and dryer run on one 2 pole breaker. Always has. Lived here for almost 5 years.
Sounds like you might have a loose connection some where !
this is limiting the current available,
With a light load there would be little loss,
which is why the meter read ok !
but put a serious load on,
and now the loss is now substancial.
Burnt out contacts, faulty wire, loose conections.
Discussion Starter · #9 ·
in my homes electrical itself? Because tthat won't explain why the oven doesn't work either.... wondering if maybe I got some sort of power surge and it just blew out a fuse or wire in the oven and dryer...not sure
I=E/R
The control panel is most likely a 120 v part of the appliance so an open neutral somewhere in that daily chained circuit could affect only these two appliances. You will have to start at the panel board (circuit breaker box) and then the two connection points for the appliances and check for loose or corroded connections.
Discussion Starter · #11 ·
Well I did check the breaker, and actually bought a new one thinking that was it.
Are you getting 240 volts at the dryer receptacle? Are you getting 240 volts at the overn receptacle or junction box?
Discussion Starter · #13 · (Edited)
Im getting 240 at both outlets. BUT. I tested the leads on the back of the dryer. I get 120 on one side and 50 on the other. But when I disconnect the black wire, it measures 120.
So. From the black wire to neutral I get 50, and red to neutral get 120. But when I disconnect the black wire from the back of the dryer, I get 120.
1 - 13 of 13 Posts
