When I get finished coating and sanding (which definitely won't be today!), what should the drywall be primed with? The can of Gardz suggests using it as a sealing coat on top of the joint compound before painting.
Given that I've used a mix of hot and premixed mud, and can't be sure I won't be sanding back into the hot mud in spots as I finish leveling the surface, that would seem to be sure to uniform the surface as well as block moisture, if their claims are to be believed. What say you to this idea?
