Hi everyone,
Before I start, you should note that this is a cistern tank, and not a well, but from what I understand the only major difference is that my pump is in the basement instead of 100ft down a well.
I've been having some problems with my water pump short cycling for the past little while. I can draw about a cup of water before the pump cycles on for a couple seconds, then off for a couple seconds. (It's set at 25 and 50 psi for it's on-off cycle, both the pump and tank gauges confirm this) This continues anytime a tap is on, but the pump stops and stays off once the water is turned off. There are no leaks anywhere in the basement I can find (all plumbing is exposed), and since we have water delivered on a schedule I can confirm we aren't using any more than normal, so I doubt there are any leaks outside the home as well.
Obviously this isn't good for the pump and I'd like to solve it before it burns out and I have to replace the pump. The existing pump is 2 years old.
I've attached some pictures below. From what I can tell, the tank is quite old and likely isn't the bladder type, so I'm kind of lost. The first photo shows the only markings on the tank. The house was built in the early 60's, so it could very well be the original tank.
I guess my question is, where do I start?
Is this likely from too much or too little air in the tank?
Is this actually a bladder tank and I likely have a leak in the bladder?
It's hard to see, but there's also a small, old black pressure gauge in towards the back of the plumbing that hasn't worked in years and is stuck at 80psi. Is this suddenly causing an issue?
Anything else I should look for/try out?
http://imgur.com/XIkmxIh - only markings on the tank
http://imgur.com/VePRBSP - line going from pump to tank
http://imgur.com/2jYxRVD - closer view of plumbing into tank
http://imgur.com/681JzFf - side view of plumbing and pump
http://imgur.com/uCN5yBV - overall view from front
http://imgur.com/ITJZGXY - top view
Thanks for reading, and sorry if it sounds like I was rambling. I just wanted to include as much info as I could.
