1 - 7 of 7 Posts
what is the proper way to install a pressure tank for a jet pump (well)?
I think i did mine wrong 'cause the pump shuts off at 10 psi, unless there's another reason why it (jet pump)runs for 5-10 sec and shuts off
Thanks ahead :thumbsup:
It has nothing to do with the pressure.
It's a storage tank so the pump does not have to turn on and off everytime a faucet is opened.
Pressure switches come preset to a low and high limit, the pump should keep right on running it until it hits the high point preset on the switch, did you mess with the switch?
Discussion Starter · #6 ·
ok,thanks/. Turns out the pump is a 110v , and I had a 220v connected
My bad,sorry :whistling2:
1 - 7 of 7 Posts
