Why in the world would you want a water system to work like this? As posted by others, you cannot make the pressure switch behave like you want it to.Hello Daveb1,
The picture I attached is just to let you know the kind of pressure switch I was talking about. What happened is that the pressure pump is working but I want it to work in a way that when I on tap it will supply water and when I off tap it will stop. At times it will supply water but when I off tap d pressure pump will still stop working until I adjust the cut off nut. Like wise, when I turn on tap some time d pressure pump will not work unless if I adjust cut on nut. All I want is to set it in a way that it will be working automatically without any adjustment to cut on / cut off nut everytime.
Thanks so much for your support.
