The pressure in my holding tank which is in the cottage is always 10psi lower than what it is at the pump, which is down at the lake 200' away. The cut-in pressure of the pump is 30psi (pressure switch is on pump), so the pressure at the tank would be at 20psi at cut-in. My question is, since dry pressure should be 2psi less than cut in pressure, what should the pressure in my tank be when dry, 18psi or 28psi? Thanks
