When the paste is that thick it needs to be bladed off, I use my mud pan and do some "reverse spackling".You can get the paste wet ( use a sponge or even a garden bug sprayer-) let it soak in and soften the paste- scrape the paste off with a 6" mud blade ( and a 4 to clean that off the 6) - then sponge any residue left.
Lightly sand to get any bits off- and then prime with a clear primer called Gardz.
then do any repair needed- prime repair and paint.
It's just that easy!! lol
A sander would just grind the glueinto the wall.:furious:
The glueneeds to be stripped.:furious:
http://removewallpaperpaste.com/
You think this is expencive?
http://www.cpoworkshop.com/factory-...fault,pd.html?start=15&q=random orbit sanders
Not so, you read as fast as you writenot even ONCE did the article you included use the improper term glue, did you read it?![]()
Not so, you read as fast as you write![]()
