Hi all,
We had a ground level wooden patio that we've torn out in order to replace with a paver patio. The wooden patio was built partly over a concrete base and partly over dirt.
The new paver patio will cover 3 separate "areas" that probably all need different preparation:
Ok, now to my questions :biggrin2:
- Area 1 - Concrete base - this will require the least prep. Just sand underneath the pavers. This may require more than 1" of sand.
- Area 2 - Part of a flower garden - this part we'll have to dig in order to put down 4" of gravel and 1" of sand under the pavers.
- Area 3 - Dirt area that was under previous patio - this will require the most work. There's tons of trash and roots here. And this area is already dug lower than it should be for 4"+1" of base so we'll fill it with some of the dirt that we have to dig from the flower garden area. If that doesn't bring it high enough, then we'll have to add more than 4" of gravel.
- There are some posts in concrete from the old wooden patio in Area 3. Do I need to fully remove those? Or can I cut off the wooden post and leave the concrete in the ground?
- Any special considerations for where Area 1 and Area 3 meet? Should I make sure that area 3 only needs 1" of sand even if Area 1 needs more than 1". That would possibly mean that the gravel base in Area 3 would be higher than the top of the concrete in Area 1.
- Anything else I'm missing? Am I crazy for doing this myself? :smile:
