1 - 20 of 24 Posts
Please do not take offense. Many people will not open a word document that's just posted on a message board for fear of infection. It's a good practice. Cut and paste the information in multiple posts if necessary.
· Old School
No offense taken. It was too long for one post, and I know I usually won't bother reading something stretched into two posts. Besides, it has an illustration in it. I guess sometimes we all miss out on something.
Humorous thing is. You are not opening a Word document from my site. You are opening a document from the same site you are already logged into. About the same thing as opening another thread here.
· Safe, Most of the Time!!
I can't believe it, 768 views of this thread as of the date and time of my post. Yet only 67 views of a very informative document. :(
I do believe in being caucus, but the number of post and their join date is right below their screen name. I would find it hard to believe some one would stick around so long, try to make up all those post numbers just to plant a virus. But then it is possible.
That is why a good up to date virus protection software is necessary. :yes:
Willie, good info.
· Old School
Willie, good info.
Thanks, BK. But like I said earlier, the most amazing thing to me is that people just don't seem to understand that they are not opening a stranger's document... but rather an embedded extension of the very site they open every day. Oh well.
I was not aware of that either until you mentioned it.
And here I thought I was living life on the edge by opening such unknown documents. :laughing:
This is a great write up. Thanks for sharing.
As for hanging your own(non pre hung) I helped my grandpa do his whole house when I was 16. It was a lot of work. We did this because his house was older and the 2x4s are true 4" thick so pre hung wouldn't fit without an extension. We bought some oak 1 bys and ripped them on the table saw. Then used a hand planer to slightly back cut the outside edge so the trim would be sure to sit flat like the pre hungs are. Then we rabbited the top 3/4" so the top of the frame would sit on the sides. I then made a jig to route out for the hinges. I didn't have a router but did have a router attachment for my dremel tool so that is what I used, slow but worked.
Cut the old jambs out and started shimming and hanging the new frames. Then put the door stops on. Routed out for the hinges on the door and then screwed the hinges to the doors and jambs and then trimmed it all out. LOTS of work for all the doors in the house but learned a lot from my grandpa.
Hope it all worked out for you.
I "printed" the document as a pdf. Send me an email, and I'll email the pdf to you if you're interested. PDF is Adobe's cross-platform document sharing format. I wrote it with Acrobat version 9. The document did not show the door illustration correctly in Word 2007, so I changed the layout to show the illustration and text more easily. Otherwise, no changes have been made to the original.
· Old School
Discussion Starter · #16 ·
It's puzzling that you had a problem with Word 2007.
I wrote this with 2007, but I saved it as 97-2003, since many people still use that.
I just went up and opened it with 2007, and it worked fine. (You do realize the picture of the door is supposed to be right in the center of the page of text, right?) Makes it a bit of a challenge to read around, but it keeps it in context, and keeps you awake.
· Newly Retired
Thanks Willie T Very in depth post with lots of good points. I have just retired and will be using that document as a guide line. My Dad was a carpenter and I helped him install doors but when you are not going into it as a trade you don't always pay close attention to details(thats what he was there for).
Thanks again.
· Developer by Day
I REALLY hate to bump such an old thread but I have to so we can correct your thought process. Although you are uploading the file to the very forum that we log into everyday, that has absolutely no bearing on whether it is safe or not. diychatroom.com is just the server that is hosting whatever file you choose to upload. I could upload malicious content as an attachment and still infect everyone who downloads it.
Every single file is unrelated to the next in terms of web storage. Just because they are stored on the same server, as I said earlier, has absolutely no bearing on the safety of it. You could get infected from google.com if someone where to maliciously upload it to their server. It doesn't generally happen because we have security measures, and those are they very measures giving you a false sense of security when you download a file from what you think to be a safe source.
This is why virus protection was created. If your theory we're correct we could all just download safe files and have so-called trusted sources. But, alas, we do not.
1070 downloads as of now and nobody is whining about any virus...
Besides, Google bots would have id'd it by now as a dangerous item.
On top of that, the Server can have its own heuristic scans of the attachment.
I'd download it and read it, but I think I did already. Good info to have if you need it.
Willy is not about to post up any virus laden files... guaranteed.
Pre hung doors made easy. With door in frame measure width of door at the top, measure width of opening, fill the rough opening remainder evenly with a cedar shim on each side at the same height as the top of the door frame. Make it 1/16 or an 1/8 tighter. with a wooden block and hammer squeeze the door in place it will hold its own. Level the top if the floor is out. Shim the jam with a 1/8 margin all around the door. secure the jam, trim the shims, trim with casing, have a beer
1 - 20 of 24 Posts
