Hi, I've been installing a new plug outlet and ceiling fan in the bathroom. I have it set so the power has been spllit at the box coming in - 1 wire runs into a 2 way switch which in turn runs to the light above the vanity and the other switch to the ceiling fan. The other line where I splitt at the box coming in runs to a new outlet. I am getting power to all 3 sources when i use a tester (makeshift lightbulb with wires) and the switch is working fine in terms of cutting/supplying the power, however when i wire up the fan, or the vanity light or plug anything into the outlet they don't work. Any ideas? Thanks.
