My power outlet for my food disposal suddenly doesn't work anymore. What could be the problem? I'm seeking help on how to fix this myself. If there is any help I would be happy..
you aren't being very helpful...pull the disposal outlet out and tell us what you see...check the disposal switch...we don't have a dishwasher.. we only have the receptical plugged in..
Attached to your outlet you should see 3 wires. One is hot, one is neutral, and the other is your ground. When someone says you have "a bad neutral," they are trying to tell you that one of the wires (the neutral) might be functioning properly. There are a number of reasons why it might not be functioning properly, but first we need to make sure that's the problem.what do you mean by bad neutral?
Take a picture of the red amd black dside of the outlet. The little tab should be broken between the two.
