The basement room and bathroom has no power. I tested the circuit breaker and the circuit breaker is good. I checked the GFCI outlet in the bathroom and the test button would not move, it seemed stuck. So I assume the GFCI outlet was bad. I changed the GFCI outlet and there is still no power. The wires are live because I tested them. But the indicator light on the GFCI outlet is off and I also plugged something in the outlet and still no power.
I also swapped the 'line' and 'load' wires just to make sure I didn't mix them up, and still no power.
Also, I tested the adjacent outlets in the bedroom and the wires aren't live when tested. Could it be a bad light switch? How else can I troubleshoot this?
Thanks in advance!
Thanks in advance!
