1 - 6 of 6 Posts
I have a 200' long driveway. I am considering putting small lights along the driveway.
1. Should these lights be on a separate breaker?
2. What guage wire should I use?
A "Handy Husband"
I would go with low voltage LED.
Licensed electrician
Lighting in Canada is limiTed to 15 amp circuits. You may need to up size the wire for voltage drop.
Reactions: SandyKim
Normally for outdoor lighting like that you would use low-voltage landscape lighting. It's much easier to run the wiring for it and you don't have to worry about bearing the cable deep or using conduit.
1 - 6 of 6 Posts
