The outlets and lights lights, whole house, just stared flickering periodically. I tightened all screws and the mains in the breaker box (square D) 9 years old maybe. Shouldn’t be a problem. Can it be a bad transformer or connection at the pole? The main line coming in does sag a little bit more than I remember. I Contacted PUD. Anything else I should check? One line shouldn’t effect the whole house, correct?
Thanks
Super Moderator
The line from the transformer to the house could have a bad connection at either end.
Too much load on your lighting/outlet circuit? if you have spare breaker spots open in your panel maybe try splitting them up. Do they flicker randomly or is it when you turn on a window AC unit or a microwave?
