Hi all,
My vacuum cleaner is 240V - 250W, I use it mainly in the basement and I am fed up to carry around my heavy step-up converter, therefore I have decided to convert one of the many 120V outlets to 240V.
Here is the list of things I'd like to do for this project:
1) Choose the right 120V outlet, possibly one which is end of the run or stand alone with direct wiring to the service panel (also in the basement).
2) Given that I need 1A I'll go for the min. load available in terms of breaker: 15A double pole.
3) If possible, I'd like to use the existing wiring 14#, use the black as one hot and mark the white with red tape and use it as hot too.
4) Connect the bare copper wire to the ground screw (and pigtail to the metal box)
Material to purchase:
- One double pole breaker 15A
- One tandem blade NEMA 6-15R receptacle (single)
- One NEMA 6-15P plug
Am I missing something?
I mean, connectors or so?
Is the procedure correct?
Thank you
Alex
Thank you
Alex
