Hi there. New Homeowner here.
My house has a small sun room built on the side of the garage and built quite poorly, at that. They built three of the frame walls right on a big patio slab that extends way beyond and as one would expect, water has gotten under the walls and door thresholds and rotted the bottom plate, sheathing and studs.
My plan is to work one wall at a time following these steps:
1) Build temp wall to support pre-fab roof and walls via roof
2) Cut and remove damaged timber
3) Pour a 2-3" "sill" or "footer" with self-leveling concrete using adhesive to bond to existing slab and tie in with other sills.
4) Replace framing with pressure-treated wood over a moisture barrier
5) Reset original thresholds in grout (if room under doors) or tapcon thing metal thresholds that have less height.
6) Seal up further with 100% silicone and float drywall
Is this the best path forward? There is good grade to the slab so there really isn't much water along the bases of the walls.
