Hi.
I'm trying to figure out how the heck to get all my wires into the little steel box for the Pot Light (CAN) I have. I have 14/2 coming into Pot light from dimmer switch then 14/2 going out to next pot light. I have a total of 8 Pot lights on this circuit. This is for Manitoba/Canada if that helps.
The Switch box will have only 1 dimmer switch. ( I need to find a deeper single box as I can't find the decorative faceplate that will cover two box's?)
The Room Layout with the Cans.
And Finally the Pot light wiring???
Thanks
Matt
- Are they all supposed to fit inside the box and the lid put back on?
- Do you put the wires through the holes on the side?
- Also I want to add insulation for sound dampening but these box's are only rated for CFL's if I do that. Can I just keep the insulation back from the lights say 6" all around (which would kinda of make it not insulated and mess up the entire sound proofing but whatever)?
- On the Box for the Pot lights it says wire clips are recommended. What exactly do these look like?
Thanks
Matt
