1 - 12 of 12 Posts
Hello everyone. I'm wondering if it's possible to wire a constant outlet (one that always has power) from an outlet that is controlled by a light switch. My garage door opener is connected to an outlet in the ceiling of the garage that is controlled by a regular light switch. I would like to install an outlet that always has power to plug the garage door opener into, and would like to keep the outlet that is controlled by the switch so that I can install hanging floresent lights that will turn on and off with the light switch.
Does this make sense?
Thanks!
Licensed Electrician
If that switch doesn't control anything but the GDO, you can splice the wires that go to the switch together. That will make the outlet always hot, but it will also make anything else controlled by the switch always hot as well.
Discussion Starter #3
Currently there's an outlet that is switched. I need to keep that switched outlet an add an outlet that is always hot.
Is both outlets controlled by switch, if they are u will need another wire, unless a three wire was already run. Then u can just break the Lil tab bridge on the hot side the receptacle.
Discussion Starter #5
There is only 1 outlet right now, controlled by the switch. I need to add another outlet that is always hot (not controlled by the switch).
Without more information, such as wiring in the switch box and outlet box, we won't be able to tell you for sure, but it does sound like you will need to run a new wire.
"MAYBE"
It all depends on how the wiring is laid out !
If the power goes to the outlet first,
and the switch loop goes from the outlet to the switch.
Then yes it is possable!
If how ever it is
power goes to switch,
and switched power then goes to outlet.
Then NO is is not possable
without adding extra wires.
Do you know which it is ?
Mike, is the whole outlet switched...I'm thinking it is. If so you will need another wire or forget about the switch and make the connection there. Got any idea how it's wired?
Thanks for the replies. I'm not sure how it's wired, will looking at the wiring at the switch tell me that?
No, you will have to pull the outlet and look there. Shut the breaker off if you aren't comfortable with that....and post some pictures if you can.
Discussion Starter #12
I am very comfortable doing that, thanks! I will do that as soon as possible then report back. Hoping to have time this week but I may have to wait until the weekend.
1 - 12 of 12 Posts
