Our A/C for the last week has had some strange issue. The thermostat will cut off intermittently (by that, I mean the screen goes blank, no power to thermostat). It seems to work fine in the evening and morning, but often when we come home from work, we'll find it off, or having just kicked back on. Yesterday, it was in the 80's and pretty hot in the attic, and we had this issue. I am not certain it's heat related, just a theory.
When it works, it works great. We have a new compressor and evaporator coil, but the furnace we did not replace. Is it possible the circuit board would intermittently cause power loss to the thermostat? When the thermostat is off, the light on the board goes off, so it seems none of it is getting power.
Before we go and replace the entire furnace, I'd like to try replacing just the circuit board, transformer, switch, etc, but am not sure what the most likely culprit is. It's going to get hot soon! It's Texas! Any ideas?
Thank you!
edit: thermostat, when it cuts off, cuts off completely. No power, blank screen. Just clarifying.
Thank you!
