soaker tub and backsplash, kitchen backsplash, Var fixes around the house.
Hi,
Some upwind handlers (split heatpump) have the fan under an inverted a-coil.
Is this any better or worse that the a coil below the fan?
The tech said it is Positive airflow... This unit was a Trane Hyperion GAF. My instincts tell me that with out really excellent filtration this could run into problems if it needed cleaning... or if the coils ever started dripping... as it would hit the electronics.
I do like the idea of enclosed insulation... which sounds easy to clean.
Still expensive compared to some other variable speed fan handlers.
