I just bought my first compressor, a factory reconditioned Porter Cable C2002 pancake air compressor. It seems neat, and seems to work fine, but when running, there is a good flow of air coming out of the cowling vents on my left (tank hose side). Sounds like a serious air leak inside, a hiss loud over the regular loud. That short hose to the tank is too hot to touch, but this escaping air flow does not seem hot. The air flow might even be from a good fan (I dont see an easy way into there) , but the sound is a strong hiss like a serious compressed air leak. This hiss and air flow stops when the motor stops, and it holds pressure OK. Seems fine in all other respects, except for this internal hissing.
So on this model, is this a normal cooling situation and no problem, or is it likely to be a real problem? Advice appreciated, thanks.
