Hi there,
I am looking to build a 4' x 7’ portable dance floor for Flamenco dancing at home. It may be placed on top of hardwood or laminate. The floor will consist of three layers - a 2mm-thick vinyl dance layer on top, birch or maple plywood underneath, and 3”x3” (1/2” or 3/4” thick) foam blocks underneath (blocks are placed a foot apart to the centre).*
1. For the foam, is it better to use EVA or EPS (Expanded Polystyrene)? Which has better protection from injury as there will be a lot of stamping.
2. For the plywood layer, which of the following options will be sturdier on top of the spaced foams?
Option 1: One large piece of 4’x7’ birch or maple plywood that is 3/4” thick.*
Option 2: Two layers of birch or maple plywood, each layer is 3/8” thick. Top layer consists of two 4’x3.5’ plywood. Bottom layer consists of two 2’x7’ plywood.*
If option 2 is better, what’s the best way to connect the pieces of plywood together, *for each of the smaller pieces making up the 4’x7’ layer and between the top and bottom layers?*
Thanks! I’m not handy so I would appreciate explanation in simpler terms.
