Where is your electrical service and meter in relation to the railing? Is it an overhead service or underground?when I touch it without shoes on standing on a bluestone step. Porch is concrete with the railings mounted into the concrete. I didn't believe it until the wife showed me. Anyone have any ideas on how to fix this? Or the cause? Thanks
I'm not an electrician but I have a good understanding of how it works, I've done HVAC work for the last 40 years or so and have seen a lot. This issue reminds me of a customer that was having issues in their place of business. I remember the secretary actually got shocked when she touched the commode handle. I don't remember but suspect they had light flickering issues as well. Turns out they had a problem with the neutral wire coming into the building. Seems the electricity was searching for a ground. I would be really worried about getting this fixed quickly. I think it's much more dangerous than the original poster realizesWhere is your electrical service and meter in relation to the railing? Is it an overhead service or underground?
Were there any electrical lines buried in the ground before the porch was built?
Have the lights in the house been flickering?
Only if there are other problems that are much more significant. How did you fix the receptacles? Were the wires mislabeled, or just connected to the wrong terminals? Was it only H-N reversed, or was ground involved?I found outlets with reverse polarity - 1 on the porch, 1 in the nearby bathroom, and 3 in a basement bar. They have been corrected. And so far no shocks on the railing. Do you think this could have been the cause? Thanks
I'll expand on mp's post. Was a jumper between the ground terminal and neutral terminal with reverse polarity? A reverse polarity bootleg ground is very dangerous and difficult to detect. It's the only time a non contact tester trumps a voltmeter.
