Dry before you buy is the important part about avoiding checks and warped, fir can be as bad as any when you put it up wet.I’m building a porch with exposed rafters from below in which the bearing beams will also be visible. I’m leaning towards Douglass fir to maintain minimal wood check& shrinkage. Any thoughts? Thanks
RaftersIf the lumber is within ... i think 18” ... of soil it must be pressure treated.
I didn’t realize that it has to be installed dry! It will deserve some moisture even after it’s built. Grr!Dry before you buy is the important part about avoiding checks and warped, fir can be as bad as any when you put it up wet.
That isn't what usually causes issues, it is usually when you cut down a tree, cut it into lumber and all the stresses relax as it drys.It will see some moisture after it’s built.
Ah ha. So I see, said the blind man.Rafters![]()
Also, people sometimes use incorrect terminology, so you never know!Ah ha. So I see, said the blind man.
However comma he said he is building a porch,and planning to use DF framing. I wasn’t sure how far he was going to go with the DF so its worth noting.
