I am installing 6" x 36" 'wood look' porcelain tile over 6 year old concrete basement floor. Floor is in good condition with no cracks and level so I have no concern with the condition of the substrate.
However, I am installing nearly 700 sq/ft which will cross at least one wall-to-wall expansion joint (perpendicular to direction of tile) and 2 minor (< 6 ft) expansion joints.
I know my options are either using a product like ditra (which increases my cost of project by 50%) or carry the joint through to the tile spacing. Carrying the joint through is not an option given the size, pattern, and direction of the joint through the filed of tile.
How frequently does a concrete basement floor (its a 13 course basement so the floor is well below frost line and not subject to wide fluxuations in temperatures) expand enough to break tile?
Based on experience, how high of a risk do you attribute to tiling directly over the concrete?
Ive used ditra over an exterior patio, tiling over expansion joints, with success so am experienced using that product. Are there any other products that do the same things at a lower cost?
Hypothetically, what If I apply ditra on both sides of the expansion joints only (and the rest of the tile is applied directly to concrete). Would that 1/4" difference over in the middle of a 600 sq/ft field of tile be noticed and would it affect the stability of the floor? (not saying I am going to do this but I just wonder about the feasibility)
