Hello all this is CSD and this is my first post. I removed a wood floor that buckled on a moist cement slab. I used a scraper to remove glue from the slab and a bead blaster to prepare for a silicate penetrating sealer called Bone Dry. I have had the slab tested and the moisture apppears to be gone. I would like to lay porcelain tile directly on the non porous slab. Is there a product (thin set, adhesive, etc) you can recommend that would work well with these conditions. Thank you for your help!
CSD
Tileguy
Thinset manufacturers tell us all sealers and primers MUST be removed AND the concrete should be porous so thinset can bond.
I can't comment on the level of moisture since I have no info about that. If you had a hydrostatic moisture problem, I think you still do. If moisture tests show an allowable level, then fine in that regard. But the thinset has to bond.
I think the smart thing to do it to ask Bone Dry to certify your conditions and give their blessings with a written warranty. What we or anyone say mean nothing.
Jaz
