Here is some back round. 1930's home in excellent condition.
2nd floor bathroom remodel. Bathroom measures 86"x74" (measuring up to tub)
Joists are 2x8x10 16" on center running the 74" width (parallel). One end sits on load bearing beam, other end on studded wall with 16" on center 2x4 (basically 2x4 under each joist)
Subfloor is as seen in picture below in backround. Appears unknown width but 3/4" T&G, and on top of that is 1/4" ply with linoleum glued (done in 1980s) and then vinyl on top
My plan is take up vinyl, take up linoleum and 1/4" floor. Then add 5/8" or 3/4" plywood over the existing 3/4" T&G, level, use either DITRA or 1/4" Hardibacker then tile with 12x24 that are 4.5lb/sqft. For the joists, my plan is adding 2x8 perpendicular to joist span to stiffen and help with twisting.
All dead weight of new items (linen cabinet, double vanity) sit nearest load bearing wall.
Tub is alcove 60x32x20 soaker sitting parallel to beam directly underneath one, plan on strengthen with a box method. Finally, 1/2" Hardibacker around tub with same tile for floor on the tub surround.
A conservative delfecto says I am good to go (L/367 for unknown wood as no stamps). Joists are in very good condition, with only minimal notches for plumbing.
Any other recommendations for tiling the floor?
